- JIMNLINExplorer IIISounds like her F150 has the power however her most important performance is does the truck have the tire/wheel/rear suspension to carry her load (the hitch...trailers hitch weight...gear in the bed and back of the cab).
For newbs I would have her drop by a local CAT scale with the trailer in tow and get the trucks front and rear separate axle weights. This will tell her if her F150 has overloaded axles/tires/ rear suspension. - egh33ExplorerOk, the trailer the daughter got is just under 8000 lbs. Loaded I bet it's a little more.
But that Ford pickup 4x4 can tow that thing with no problem at all.
Where her house is there is a concrete drive that is more of a climb than she will ever encounter on any highway. She drops it in D-2 and goes up there with no problem at all.
There is a gravel drive around the field also if she goes in either way she don't have to turn around.
The second time she took it up to her house, she went up the gravel drive. She said she stopped about half way up and it spun in the gravel when she stared to go on up. She said she just put in the 4 wheel drive and went right up with no spinning in the gravel at all, She even backed it in beside her garage. She is really proud of her self. She even made a trip to Branson ,MO. with her 2 sisters was able to pass every thing but a gas station. - Timmo_Explorer II
Grit dog wrote:
Timmo! wrote:
I pull my 20' Nash 19B trailer with my F150 (see signature) and I have no problem pulling it, except going up inclines greater than 6%. On those occasions, max speed is 25 mph and I monitor the tranny temp.
The GVWR for my Nash is 7000 lbs with a carrying weight of about half that, and a hitch weight of around 350 lbs.
The GVWR for Transcend Grand Design 30' is almost 10,000 lbs with a carrying weight of 7820 lbs, and a hitch weight of 780 lbs (2x my Nash).
https://www.granddesignrv.com/showroom/2021/travel-trailer/transcend-xplor/floorplans/30rbs
My F150 has a maximum towing capacity of 9300 lbs, with a payload of 1670 (or about 1300 lbs after trailer is hitched).
Assuming your daughter's F150 has a payload of 1670, then once she hitches the trailer, her payload will be less than 1000 lbs. Add a few riders in the cab, camping gear in the truck bed and full tank of gas--and poof, your at the maximum.
But the trailer you posted is almost 35’ and your truck is 16 years older and your trailer much smaller and lighter so not sure what comparison you’re trying to make.
Just sharing my experiences. - Grit_dogNavigator
But the trailer you posted is almost 35’ and your truck is 16 years older and your trailer much smaller and lighter so not sure what comparison you’re trying to make. - TerryallanExplorer II
egh33 wrote:
It's a Transcend Grand Design 30' I forgot the weight already.
Can have more info when she comes up to see us next week end.
No matter what F150 she has. That is gong to be pushing it. 8000lb dry - philhExplorer II
SAE std that the OEMs all work to, weight of two 150lb people and full fluids are already included. - Timmo_Explorer III pull my 20' Nash 19B trailer with my F150 (see signature) and I have no problem pulling it, except going up inclines greater than 6%. On those occasions, max speed is 25 mph and I monitor the tranny temp.
Assuming your daughter's F150 has a payload of 1670, then once she hitches the trailer, her payload will be less than 1000 lbs. Add a few riders in the cab, camping gear in the truck bed and full tank of gas--and poof, your at the maximum. - teejaywhyExplorer
:E - egh33ExplorerIt's a Transcend Grand Design 30' I forgot the weight already.
Can have more info when she comes up to see us next week end. - Grit_dogNavigator
capacitor wrote:
What did Ford tell her and what trailer did she get?
For whatever reason, OP asked a very specific question with very generic info given and has yet to provide any meaningful content as to how the truck is built.
This thread is done. Shouldn’t matter to us since it doesn’t matter to the person who asked the question.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
