Mi2bugz
Jun 26, 2018Explorer
Weight question
I have a:
2012 Dodge Ram 1500 4.7L V8 65RFE trans quad cab 4x2 Rambox 6'4" bed
GVWR 6700
GAWR 3700 front / 3900 rear
GCWR 11,250
3.55 axle
Bumper says: 5000 lbs max gross trailer weight / 500 lbs max tongue weight
RV dealer says trailer life towing guide says can tow 7300 (I see that also) BUT ram trucks.com says max trailer 5950. They recommend the husky weight distribution hitch.
We were looking at a 2018 Avenger ATI 27DBS based on the towing guides limits. Actual weight is 6450 tongue weight 742 (tongue weight not actually weighed on scale...yet).Only 3 occupants on average 250 lbs per person (per dealer) in TT. RV dealer says we do NOT need to include weight of passengers and TV cargo in weight factor (GCWR). Unless I read it wrong...I read you DO need to factor in passengers, gas and TV cargo. So since reading ram trucks.com limits I am second guessing choice.
My questions are:
1) what weights do I go by (I am guessing manufacturer for safety/insurance/NHTSA/DOT regulations)?
2) after telling dealer about my concerns the dealer says (in writing...text message) "GM said you should be able to pull that camper still", "I can't see your truck only being able to pull 5900 lbs and being a V8". Being a V8 I was surprised to see the weight listed by manufacturer as 5950. Does that sound low for a V8?
3) does weight distribution hitch allow hitch to hold more weight then bumper states (500 max tongue)
4) at 6450 TT weight I need to be between 645 and 967 (10-15%) on the tongue correct?
5) I have ridden in a TV towing a TT before and felt extremely ill from my the push and pull (no up and down or side/side) motion. Is the forward/backward motion normal when pulling TT's? If it is normal...can anything help reduce it?
6) we only have 3 payments left on truck so we really don't want to have a truck and TT payment. Are my only options upgrading the TV if we really want the Avenger? Or are there modifications to the TV we can make to make it capable of towing 6450 and supplies...legally?
Sorry lots of questions but would like some insight from people with experience NOT making a commission. TYIA ~ Nicole
GVWR 6700
GCWR 11,250
3.55 axle
My questions are:
