12thgenusa wrote:
totaldla wrote:
I'm really getting confused by this discussion as I can't tell if the "problems " are due to the charge controller quality,
There are probably more of these units installed by manufacturers than any other type so failure numbers might be higher, but not by percentage of units in service.
or due to manufacturer stupidity, Yes
or due to forum talk that disproportionately focuses on a few failures. Yes
If I found an RV that in all respects was what I wanted, the type of converter would not be a deciding factor. If you like it, buy it. If you find the converter doesn't perform to your liking, try a mod or replace it.
You're right of course. The converter is certainly not a deal breaker. I'll stop my whining now :)
