- AcdiiExplorerIn a real hailstorm that would damage aluminum to the point it would leak, it would also damage fiberglass to the point it will leak. If fiberglass is hit with hail that dents aluminum, it will also damage the fiberglass shell, but it takes a while before the damage makes itself known, sometimes it will start to crack and open up as moisture enters, and other times, nothing happens, but heavy enough hail will spiderweb the fiberglass, you just don't see it. My Coleman got nailed in a heavy hailstorm that cracked the windshield of my truck, and has plenty of tiny marks all over the front, but has not leaked at all, they are just cosmetic.
The aluminum and fiberglass trailers make for a larger lighter trailer than can be done in a stick and tin, but some stick and tin can be lighter in weight than a similar floorplan fiberglass one. My 274BH has over 3K pounds of cargo capacity and GVWR is 7600. I saw a similar floorplan in glass that had the same GVWR but 1000 pounds lower CC.
Both will leak eventually, and the fiberglass one, once they get wet and start to delaminate, they are done, stick and tin, you can seal up the leak, replace the interior that got damaged and keep on camping. - colliehaulerExplorer III
Lantley wrote:
Like I said in a earlier post I own both, The fiberglass RV'S I get a discount on from my insurance, (I live where it frequently hails in the spring).dodge guy wrote:
I personally like my sides trailer. I have a few dings in it from things that jump in the way. The issue with smooth side trailer (fiberglass) is that whatever would ding/dent aluminum sided trailer will crack the side of a fiberglass trailer.
I agree that it may be easier to do a DIY repair on aluminum.
However there are many things like hail that will harm aluminum trailers but will have minimal to no impact on fiberglass trailers. - RedRaider44ExplorerStill camping in my 2004 aluminum sided Jayco.....but looking seriously at the same exact Transcend you are looking at.....if fact, I prefer aluminum.
No leaks, a few minor dents, and no delamination to worry about.. - NWnativeExplorerWe chose Aluminum....
- 2012ColemanExplorer II
sgfrye wrote:
RICK-ards Red wrote:
Have had both types of trailers, no issue with either type. If you like the floor plan and it works for you - go for it. To me a floor plan that works for us and our travel style is more important.
x2
our first TT was aluminum.
current TT fiberglass
enjoyed both. no problems with either will diligent owner maintenance
X3
My Coleman was aluminum sided. Kept it waxed and brand new looking. I used Meguires cleaner wax, which works wonders on black streaks. If you keep it waxed, the streaks come off during normal washing. - sgfryeExplorer
x2
enjoyed both. no problems with either will diligent owner maintenance - spoon059Explorer II
ScottG wrote:
We had several corrugated aluminum RV's. All leaked because of the undulating shape of the siding. It was impossible to stay ahead of the water intrusion, rot and mold. Had to take one of them straight to the dump.
What? Aluminum siding is not more susceptible to leaking than any other type of siding material. Water would have to go down the siding, back up the backside, down the joint and then back up again to reach behind the siding. That is some magical water!
I think perhaps your issue was water getting in some other way...
OP, I have aluminum because it is cheaper, lighter and easier to repair than fiberglass. Moisture behind fiberglass walls will cause delamination which is very expensive to repair. Moisture behind aluminum can be remedied by removing the aluminum panel, repairing damage and replacing aluminum panel. - LantleyNomad
However there are many things like hail that will harm aluminum trailers but will have minimal to no impact on fiberglass trailers. - dodge_guyExplorer III personally like my sides trailer. I have a few dings in it from things that jump in the way. The issue with smooth side trailer (fiberglass) is that whatever would ding/dent aluminum sided trailer will crack the side of a fiberglass trailer.
If you really like it I would let the type of construction be the deciding factor!
And FWIW I wax mine at least once a year if not twice. I like to know mine is maintained properly. And getting up close while your waxing lets you find and fix potential issues! - TurnThePageExplorerI've never waxed my 2004 wood framed, aluminum trailer either. It has lived outside 24/7 since new, and has snow on top of it now. It's never leaked and has been easy to keep warm or cool. I think sound travels right straight through them. You can hear pretty much everything through the walls.
If you're buying a trailer, you better plan on doing maintenance annually at least to prevent those evil leaks that are constantly talked about.
About Travel Trailer Group
44,028 PostsLatest Activity: Apr 06, 2025
