jaycocreek
Oct 21, 2018Explorer II
If I put the 350lbs into a trailer, is it better or worse, given the trailer has its own weight addded to the GVWR?
GVWR don't mean much in your situation but axle capacity does, when towing with a AF 811.As far as I can tell the AF 811 already puts about 7500(Total weight) or so pounds on the rear axle and adding a trailer ads more weight on that rear axle...
If your rear axle is rated for over 8K,go for it...Actual axle rated weight by the manufacturer, not the door sticker.
44,029 PostsLatest Activity: Jan 20, 2025
