Probably at some point, because they never used to check them, they had a trailer bearing finally go bad on them. In Alaska, you usually see several open trailers sitting along the road from Anch to Fbks without a wheel hub when hunting season rolls around. These are trailers used once a year (maybe even not for many years), they overload them with four wheelers, hunting gear, and then head off down the highway at 70+ mph. Then the same thing when the first good snowfall hits and people get out the snowmachine trailers for the first time in a long time.
What I find interesting is tires. Some talk about checking their air pressure every day. That's not a bad thing to do at all - a blow out on a MH or TT can be expensive, but when you ask them if they check the air every day on the car or truck they drive every day when home, you never hear back from them.
Or, when they ask what to do with the tires when the RV is in storage such as should they raise the tires off of the ground, should the tires touch the grass, should the tires be stored on wood or concrete vs gravel or pavement. If you ask them how they stored the car or truck they left at home for six months while traveling, they don't answer.
Why are only RV tires important?
I do check mine when I stop, but it's more a part of getting out of the MH and limbering up. After whopping the same tires with the same hammer for a long time, I don't need an air gauge to know if the pressure has changed a couple of pounds or one tire is much different than another. A quick touch of my hand to a wheel hub is enough to know if I have a heat problem.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
