where to buy brackets for cabover struts
Mote
We have a 2001 Lance 1030. The person we bought the camper from had it on a 93 chevy extended cab. She gave us the cabover struts in the deal. Where can I buy the brackets for my 96 extended cab dodge truck? I'm hoping I can use the struts she gave us as both trucks are extended cabs.
thanks,
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
17 REPLIES 17
ticki2
sleepy wrote:
Lance owns the patents... no one else can manufacture them
sleepy
That is true for the Lance design it was patented in 1998.
However there are other designs , here is one patented in 1968 . My 68 Avion still has the brackets for this design .
http://www.freepatentsonline.com/3402961.pdf
'68 Avion C-11
'02 GMC DRW D/A flatbed
nycsteve
The struts from my supercab were not long enough for my crew cab when I changed over. Check with Lance.
12V_Cummins
How i see it is if your center of gravity is well in front of your rear axle you do not need cab over struts. I guess lances just have a further rear COGs than most campers?
camperpaul
sleepy wrote:
camperpaul wrote:
Why do you want to use those struts?
Here is why you shouldn't:
When you are on the road the truck frame flexes and twists.
When a TC is on the truck, you can see this twisting because the cabover is moving relative to the cab.
It you restrain the cabover with those struts, the stresses can damage the TC frame.
You cannot stop the flexing of the truck frame by using the struts.
Paul,
It is obvious that you don't have a Lance (or maybe have never had a truck camper.)
What is called a Lance Strut is actually a "DAMPER" (or a shock absorber without a spring)... it is an oil filled cylinder with a piston.
The truck camper is free to move in any direction that he would normally move with the "strut" in place....
The "Strut" just slows down the motion and the "fly back"
A gust of wind from the side isn't noticed... as when a bus or large truck passes by
And... It also retards porporsing when the roads create that phenomana.... to the point that it just doesn't happen (and porporsing is unpleasent)
They are well worth the money...
I have had them for 10 years... and have allowed others to drive my T/TC with them on and with them off. Everyone that has tried them while driving my truck has liked them.
I have owned two TCs, neither of which were Lances.
The first was a 10.5 ft. "Pathfinder" and the second was home built. Both had 5 ft over the cab beds.
The Pathfinder met its demise when a friend decided to use the loading jacks to level the rig thus tearing the anchor points out of the camper; we had to use cargo straps to get the camper back home.
The 12 ft home built was constructed using heavier lumber for the frame and various items I could salvage from the Pathfinder.
In the ~20 years I owned TCs, I have never experienced porpoising, only the normal frame twisting when on marginal roads with the 3/4 ton Chevy crew cab PU truck.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
jefe_4x4
What Sleepy said. I've had them for 10 years and do enjoy them on the highway. You just need to know when to hold 'em and when to fold 'em. When off-road, they are easily removed for frame-undulating situations. I ordered them directly from Lance and received them within a couple days. And, btw, some mfgrs frames twist more than others. I'll let you figure out whose frame flexes the least.
regards, as always, jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
sleepy
Paul,
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
sleepy
Mike... they have been selling to the public for some time unless the recently changed policys agaim.
They also work on other brands of RV's since the great recession
They went from more than 500 employees to less than 100 total... workin 32 hours a week during this time.
Mike_Tassinari
Good morning Everyone.
To Sleepy.
I was not aware that Lance Cal sold their parts to "end users" like you and I.
It was always my thought that you had to go to a Lance Dealer to purchase parts.
Has Lance Cal. change their policy or is Mikeee just all wet behind the ears and have mis-read this entire post. LOL
Mikeeeeeeeeeeeee
2002 Ford-4x4-Extended Cab-Dually-Lariet-Powerstroke Diesel--4.10 gears--Ranchero Adjustable Shocks-55 Gallon Extended Fuel Tank--4 Extra Main Leaf Springs-1 Extra Helper Spring..Independant Second Altinator(100AMP)to Charge MY Twin 275 AH. Deep Cycle Battery Bank tucked under the truck bed....
2001 Lance-11&1/2 Ft.-Model 1121/slide/out with all the Toys&2000 Watt Inverter
camperpaul
Paul
Single - Full-timer
2005 Four Winds 29Q
sleepy
Does everyone realize who the manufacturer of the Lance Struts is?
It is Lance... everyone else has to get them from Lance
Send me money and I'll have Lance drop ship them to you... of course I have to make expenses Wink, wink
Or you can cut me out, and cut anyone else out... Phone lance... get your order faster... probably cheaper... and for sure... the correct item.
Just a little something to think about.
Have a good weekend!
sleepy
Mike_Tassinari
Hello Everyone.
I have used TruckCamperSupply on a few occasions and could not be more happy. I even filled out the form for some parts that I thought were obsolete and they responded with in 24 hours.
Mike Tassinari
wnjj
deltabravo wrote:
More specific link: http://www.truckcampersupply.com/search.aspx?find=strut&log=false&manufacturer=5
The link I posted has brackets for his model year Dodge (94-02), yours doesn't.
deltabravo
wnjj
Mote wrote:
narcodog wrote:
Lance dealers should be able to get them for you. You might also look at Adventurerv.net
I looked at that website. I didn't see them anywhere.
Unfortunatly the nearest lance dealer is five hours away.
Google is your friend:
http://www.truckcampersupply.com/campinggear.aspx
