zogg's avatar
zogg
Which Oil Grade do I Need?
My 2013 Ram 2500 Hemi has "5w20" stamped on the oil filler cap. However, the owners manual says to run "5w30" with a gross weight of 14,000 pounds. Well, the truck weighs about 6200 and the TT weighs about 8000, so I am right at 14,000 pounds.
I know that 5w20 is required in the Ram 1500 due to the fuel saving cylinder shut down system, but the 2500 does not have that feature.
I am thinking that 5w30 might be able to be used all the time, towing or not. It would be a real pain to chain the oil for a four hour tow, and change it again afterward....silly???
What are the rest of you guys using??
