OP, my suggestion also is for a 3/4 ton truck for something that heavy & long. 3/4 ton trucks also have beefier brakes and frames. Used to tow with an F150. Now have an F250 with V10 and 4.10 rear end. Excellent towing machine for our 29' 7K lb TT and a huge difference from an F150. We bought it as an ex-lease return vehicle and are very pleased for the amount of $$ we have into it.
You *might* get away with a 1/2 ton for shorter trips with not much elevation change. But as you are in Ca., I'd go for the 3/4 ton. If you don't absolutely need it, I find a 2WD as a 4WD takes away payload capacity and are approx. 5" higher off the ground. Also, a long bed and/or super or crew cab with longer wheelbase will help for towing a longer TT.
I also recommend shopping for a TT by GVWR to be safe. Not only are dry weights fictitious, you can't trust published CCC numbers either. Our TT for ex. has an advertised CCC of 1200 lbs. However, loaded up for an ordinary weekend camping trip, there is only about 200 lbs of CCC left and just one full holding tank would put us over the GVWR. Manufacturers weights vary all over the place though, but the problem is you won't find any published wet weights for a TT all loaded up for camping.
Tony2238 wrote:
Can you or anyone tell me where there are scales to weigh a tt?
Besides a CAT scale, also a commercial hwy weigh station scale. Can't mess around at one though and hold anyone up. May not find a spot to unhitch the TT or to do another pass. List of state weigh stations
here. These are good if you just want the weight of your TV or just total weight of TT + TV.
Another is a grain elevator, which I have done once but not exactly the nicest of places to take an RV through and for unhooking or going for multiple passes.
Concrete plants also have scales but I would expect a pretty messy and busy place. Maybe a problem for multiple passes?
If at a CAT scale and doing multiple passes, tell the attendant inside so you don't get charged for each pass. I spent several hours once at a CAT scale doing multiple passes to adjust the WDH. All for $10. You may get stuck waiting for a line of commercial trucks to run through the scale too.
