Oct-18-2019 04:51 AM
Jan-22-2020 05:33 AM
markchengr wrote:
I have a Northern Lite 10-2 on a GMC 3500. When I weighed it ready to camp, the stock rear wheels and tires were right at the limit. I had to go to 19.5's to feel safe. It handles well now, no more sway. Most truck sway is in the sidewalls of the tires. No way would I use a 3/4 ton to carry most of the campers out there. In fact, I don't know why they even make 3/4 ton trucks. Either get a real truck or a little grocery-getter 1/2 ton. Sorry, but I'm rather highly opinionated. I guess that's an understatement. Only my opinion, didn't mean to offend anyone.
Jan-22-2020 03:54 AM
Jan-20-2020 12:17 PM
time2retire wrote:
He claimed it was good for a 3/4 ton sw truck. I was skeptical. Am I wrong?
Jan-20-2020 09:59 AM
Jan-20-2020 08:57 AM
time2retire wrote:Kayteg1 wrote:
3800 lb empty, will make close to 5000 lb loaded.
Average 3/4 tons truck has close to 3000 lb on rear axle, so that makes total zooming at 7500- 8000 lb.
Find me 3/4 truck who has rear axle rated for it?
That's exactly what I was thinking. His justification was that NL delivered the unit on a 3/4 ton and he brought it to the show on one.
As much as I'd like to see more RV dealers sell them here, they have a lot to learn.
Jan-20-2020 06:58 AM
Jan-20-2020 06:34 AM
Jan-20-2020 04:29 AM
Dec-10-2019 04:52 PM
Dec-10-2019 06:18 AM
time2retire wrote:
. . . -The hot water heater seems to run fine. It has no thermostat. The manual covers many models and mentions that it will max out at 180*. That seems high to me as I know the polystyrene insulation enveloping it can melt at 160*. Should I be watching this? I haven't let it max out yet . . .
Buzzcut1 wrote:They might not have a typical thermostat like the one on the wall for your propane heater, but they do have a preset thermostat attached to the hot water tank itself. Most RV HW heater thermostats shut things down around 140 degrees. If the thermostat malfunctions (doesn't shut off the propane/electric), the pressure relief valve will/should activate.
. . . My lance has no thermostat on the hot water heater. I have never worried about it in ten years . . .
Dec-10-2019 05:45 AM
Dec-10-2019 05:06 AM
Dec-10-2019 04:33 AM
Dec-10-2019 04:26 AM
