Viscerl's avatar
Viscerl
Why I ordered an F-450 (and expect to be overweight)
Forums everywhere are replete with explanations and warnings that an F-450 payload (~4700) is lower than the equivalent F-350 (~5700).
We've ordered a Host Cascade (which might arrive before the truck, that's a whole different story {rolling eyes}), and Randal gave me a dry weight with options of 4100 lbs. (Our config is a little weird. No gen but tons of solar with LiFePO4) We'll be towing a small off-road trailer with a tongue weight of around 200lbs, but I do plan on towing car trailers to various tracks in the future. Open trailer is ~5000lbs with the car. Enclosed is around ~8000lbs with the car. Estimates 10% tongue weight is from 500-800 lbs. We're having the Magnum 30k put on the truck when it gets here so that we can use the Supertruss (+100lbs).
4700 payload
-4100 Host Cascade
-500 stuff
-600 family (there's 2 adults, 3 kids)
-800 tongue weight
-400 water
1700 overweight.
An equivalent F-350 would be ~700lbs overweight, which honestly isnt bad.
So why am I comfortable with the F-450 at 1700?
Everything that weighs more about the F-450 is below the suspension. The F-450's payload is less literally because it pushing down on the pavement (or a scale) more than the F-350.
Half-shafts (check)
Brakes (check)
Wheels (check)
TIres (check)
Wide-track front (check)
Everything listed above assists in making the "rated" F-350 payload more safe on an F-450.
So because I think the tires, wheels, shafts, brakes, and a set of Stableloads, adjustable shocks, and a Big-wig swaybar would help a 700lb overweight F-350 be safe, I'm excited about the F-450.
Interestingly, we had to get our Host order quickly because campers built after 3/1/2019 will have a ~9% price increase (Thanks Trunp!), so we might have a camper before a truck.
Y'all may think I'm rationalizing here, but a C/C would be useless to me outside of camper use. With the F-450 I've got a ton of hard-scaping, hauling, dump runs, etc planned that I couldnt do as easily with a flatbed.
