โJul-05-2013 07:40 AM
โJul-11-2013 09:07 AM
โJul-11-2013 08:16 AM
Huntindog wrote:
Look at all the available tires to shoose from in the 16" size...This is important as any tire may suffer a road hazard on a trip and need replacing NOW...In the 16" size a quality tire will be avsailable...There are some 15s, but not widely available. This goes for both STs and LTs.ktmrfs wrote:
IMHO one of the biggest causes of TT tire failures, ST or LT, is slow loss of pressure ending in a tread seperation/blowout. You don't know about the pressure loss till to late. so I run a TPMS. I've posed the question. "Has anyone using a TPMS experienced a catastrophic tire failure on a trailer". So far I have not seen anyone reply that they have had a catastrophic failure with a TPMS, however multiple responders have said they got an early warning of tire pressure dropping, and caught a failure, and there was no other indication from driving that would have caused them to think they were having a tire go down.
So again, anyone with a TPMS have a blowout?? Has it warned you of a tire loosing pressure?
Are LT's better?? don't know, but if an LT in LRE was availble in 15" I'd give it strong consideration, meanwhile I'll be sticking with LRE ST's rather than upgrading to a 16" rim.
โJul-11-2013 06:09 AM
ktmrfs wrote:
........So again, anyone with a TPMS have a blowout?? Has it warned you of a tire loosing pressure?....
โJul-11-2013 04:27 AM
โJul-11-2013 03:18 AM
โJul-10-2013 07:21 PM
โJul-10-2013 05:46 PM
โJul-10-2013 04:13 PM
myredracer wrote:
The Marathons will have a higher load rating and are going to be better the unknown quality Freestar hecho en China ones we have now. Marathon is a better choice I've gathered from all the personal opinions I've seen. Biggest factor I see in failure is improper care, not where they are made. Too many just don't take care of their tires properly.
To throw out comments like all made in China tires are bombs waiting to happen is wrong. If that's what someone thinks, they ought to have something factual to back it up. Did the owner stay under 65 mph? limits are so limiting. What if you need to exceed it, or accidently exceed it? How good can any tire be that is limited to a lower speed that what is legal on many/most highways? Did they keep tires inflated correctly? In my case yes! How close are they to the GVWR or actual trailer wt? stock was barely legal, each subsequent upgrade increased the margin.. Multiple sets of ST tire, 3 of which were marathons all failed early. Towing on bumpy roads a lot like the washboard sections of I-5 in northern Cali? Ya got me there. All of my trips involve quite a few miles of dirt/washboard roads. My TT camps off the beaten path. I don't believe that ST tires or any tires should be so fragile as not be serviceable for the TTs intended purpose..Camping
It's self contained for a reason. Tires balanced ever? actually except for the original set, yes. I don't buy into it, but since they have always thrown it in at the last minute to seal the deal, I have accepted it.. And then insisted they use a lug plate, and watched to make sure they did it. See what I am getting at? ST tires can't take the same abuse that we're used to on automotive tires. That is for sure! Some is abuse, some is use. But ST tires need to be treated like glass, and I won't settle for that.
I've had the steel cords in 3 tires fail on tires in total while driving on the I-5 in Norcal. Two one trip and the other on a later trip. The first 2 were fairly new too. I can only imagine what that kind of road would do to ST tires. So if your ST made in China tires failed there, you'd automatically call them bombs???
I hate made in China quality just as much as anyone else these days, but you have to keep things in perspective and factual otherwise statements are meaningless. In fact, to take things a step further, then stop buying anything made in China and stop enabling them. Where are your clothes made? Kitchen plates and utensils? Electronics in your home? Just stop it already and stop whining about it. But nobody will 'cause the prices are too attractive and no-one can resist, from manufacturers to individuals. Don't get me going here!
If anyone can give me owner's experiences with Freestar tires, I'd love to hear about them. Google comes back with very little info. on them. May not have been around long enough yet to explode.
I have two choices with the dealer. Go with the Freestar load range C or upgrade to Marathon load range D. The Freestars are only 480 lbs above the GVWR which is not good. It's a no brainer as far as I am concerned without spending big bucks to upgrade from there.Is the dealer doing a warranty replacement?
If so, sell them immeadiatly while they are new and put the money towards a LT upgrade. Be an excellent time to make the jump more affordable.
Dealer is either woefully ignorant or does not want to get involved with discussing weight issues. Not a good way to run a business if you ask me.
โJul-10-2013 03:55 PM
โJul-10-2013 02:48 PM
โJul-10-2013 02:15 PM
myredracer wrote:
Interestingly, I asked our dealer why anyone would upgrade to Marathon and he had no idea!! Are you kidding me?? ....
โJul-10-2013 02:02 PM
โJul-10-2013 01:17 PM
โJul-06-2013 06:59 PM
โJul-06-2013 06:51 AM
