Why the different ratings: under/over 10K GVWR Gas
slarsen
I have a 2012 Gasser, and I'm about to take a trip that will put me on the Rockies more than once. I was looking up the ratings to find the 'sweet spot' RPM's, and this is what Ford lists:
Horsepower 385 @ 5500 rpm (6.2L V8 under 10K GVWR); 316 @ 4179 rpm (6.2L V8 over 10K GVWR)
Torque 405 @ 4500 rpm (6.2L V8 under 10K GVWR; 397 @ 4179 rpm (6.2L V8 over 10K GVWR)
So my question is: why is the 10K GVWR rated so differently? What does this mean? I don't even quite get why there is a 10K rating vs. 9.9K rating in the first place.
Anyone?
10 REPLIES 10
elkhornsun
I would expect that with the 6-speed transmission and a tow load over 10K that the trans is in a lower gear (and have the engine at a higher RPM) than at the same speed with a lighter load. That would affect the engine RPMs and in turn the power output.
slarsen
I looked up the sources you referenced, ib516, and I am greatly reassured. Thanks for your wisdom and the response. And thanks to the others that went to the trouble of responding. I love this site.
bmanning
I remember discovering the de-tuning thing years ago while researching MD trucks; IIRC even some class 5&6 trucks run tunes in the 200-240hp & 500-600tq range.
If you look at MD & HD build sheets, there are usually multiple power levels to choose from, with quite a broad range.
As already pointed out, reliability & duty cycle expectations go up and there's still enough performance to get the job done at reasonable speeds. An inner-city delivery van that'll never tow and rarely even see the freeway just has no need for 350hp.
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
ib516
From what I read, the engines are exactly the same, with the same tune.
The power is measured differently in different weight classes, hence the different ratings.
The reason for the different ratings is for licencing and insurance purposes. Some take a big jump when GVWR exceeds 10,000#, so they rate one at just under that to save people money. Again, the trucks are identical AFAIK.
LINK #1
LINK #2
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
JIMNLIN
Reliability.
Truck makers have generally always (detune) used lower hp numbers in the HD (3/4 and one ton) versions.
There also can be a lot of difference in the engines internals in some cases.
Example is GM 5.7 they used for years would get things like flat top pistons with a 4 bolt main with lowered compression in the higher GVWR trucks vs two bolt mains/higher compression and domed pistons in the lower GVWR trucks.
All done in the name of longer term reliability. What Ford does with the 6.2 could only be answered by their tech folks or a web for the 6.2 internals and spec sheets.
Ford gives the 6.2 17 different GVWR's from 9900 up to 14000 lbs in the F250/F350 SRW and DRW trucks.
Denny___Jami
Same motor same tune it's just a wieght rating thing to make the goverment happy.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
Groover
I have been trying to get the answer to that question for two years. From what I have found out the motors are identical with identical performance but rated to different specs. I have not been able to find a copy of the rating specs without paying several hundred dollars to SAE and no-one has volunteered to get a copy for me. No dealers I have talked with are even aware of the different ratings and cannot explain it when I ask. They also cannot explain why the diesel has the same rating in both trucks if it is just a GVWR issue. To further confuse the issue, the same motor in the F150 gets a third set of ratings and again I am told that it is the same motor.
transamz9
Benk is right, they de-tune the trucks they know is going to work for a living. CC truck most always have a lighter tune. They still have the power to do the work just slower.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
BenK
Assume software to protect the ICE (internal combustion engine) for the higher
class trucks...because they are not grocery getter's, but WORK trucks
Duty cycle is the key for most things as you go higher in class into 'work'
vs grocery getter's or 'cars'
Oh...also assume 'duty cycle' is understood and know what that means
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
rhagfo
Anyone?
If you have that right, it is strange that the under 10K has a higher HP and torque than the over 10K. It is stating lower RPMs, so likely the same tune on the engine, just weird.
