Why would Keystone remove egress windows from newer models?
el_jefe1
Short version: It seems to be (through a very brief and unscientific facebook poll on the Passport owners page) that older model bunkhouse trailers always had fire escape windows, but now the same newer Passport models do not. And it's got me wondering, what is the advantage to the manufacturer of putting in regular slider windows instead of egress escape windows?
Longer version: I've been discussing this at length over in the Keystone forums, and with Keystone directly. My 3290bh has no escape windows in the bunkhouse. I didn't notice it until I'd had the trailer a couple of weeks. Yes, I should have caught it before I bought it, I know.
But actually there is only one escape window in the whole trailer, and it's in the front bedroom. Other than that, it's only a door to get out, no other emergency exits. The bunkhouse is designed to sleep 6, and it has 2 windows, both are the small slider type that only open halfway. Neither is large enough for even a small child to fit through.
My argument to Keystone has been (and still is unresolved) that they advertise compliance with RVIA standards and claim the trailer meets NFPA 1192. But if a sleeping area only has one path to escape, then it does not meet that standard. In my view, if it can be proved that the trailer doesn't meet that standard, regardless of how it is designed, they should modify it to meet the standard.
But it's still got me wondering - they used to have egress windows back there. I've seen 2015 and 2016 models with them. Why remove them from 2018 and 2019 models? What is to be gained by Keystone? Especially if they've removed them to the point that they are no longer actually in compliance with the NFPA standard?
2018 Keystone Passport 3290bh
2007 Chevy Express 3500
Me, the Wife, and a whole bunch of kids
35 REPLIES 35
el_jefe1
myredracer wrote:
Here's what RVIA has to say about NFPA and other standards. Maybe try contacting them? They have no authority to enforce NFPA 1192. What they say is "The primary goal of the Standards Department Inspection Program is to monitor the pledge of member manufacturerโ€™s to build in conformance to these adopted standards.". In order for a manufacturer to get the RVIA seal, the manufacturer "certifies" compliance with 1192. "Certify" or "pledge" is more like a "cross my heart, spit to die" promise that doesn't mean much.
I've found a lot of things that don't comply with the NEC that would never happen or be allowed in building construction. I have to think RVIA's "Inspection Program" is a smoke and mirrors program.
The RVIA sticker certifies compliance with NFPA 1192. As I understand it, RVIA is a big deal. It would be hard to sell, finance, or insure an rv without it, at least thats what I've been told. I'm not expecting RVIA to do inspections, but it is at least a standard to which manufacturers can be help accountable, isn' tit? So I'm wondering if Keystone refuses to budge if there is a way to get RVIA involved or file a complaint through them.
el_jefe1
NFPA 1192
6.2.1.2 Each bedroom or area designed for sleeping shall have at least two unobstructed
paths to exit.
(Keystone is saying that since it is a curtain separating the bunkhouse from the rest of the trailer and not a door it doesn't count as a separate room. Either way, the egress window is behind a door in the front bedroom)
6.2.1.3 The path to exit shall not require passing any designated exit to gain use of another
designated exit except where any part of a bed in its normal sleeping configuration is within
24 in. (610 mm) of the plane of the nearest designated exit as projected across the vehicle.
(I don't fully understand what they are saying at the end, but the egress window is forward of the exit door, so it wouldn't seem to be a valid path to escape from the rear bunkhouse)
6.2.5.1 The alternate exit, if not an exterior passage door, shall provide an opening of
sufficient size to permit unobstructed passage, keeping the major axis parallel to the plane of
the opening and horizontal at all times, of an ellipsoid generated by rotating about the minor
axis an ellipse having a major axis of 24 in. (610 mm) and a minor axis of 17 in. (432 mm).
(My slider windows might fit this standard if they opened all the way, but they don't open far enough.)
By all of these sections, I believe the 2018 3290bh fails to meet the NFPA standard.
myredracer
Here's what RVIA has to say about NFPA and other standards. Maybe try contacting them? They have no authority to enforce NFPA 1192. What they say is "The primary goal of the Standards Department Inspection Program is to monitor the pledge of member manufacturerโ€™s to build in conformance to these adopted standards.". In order for a manufacturer to get the RVIA seal, the manufacturer "certifies" compliance with 1192. "Certify" or "pledge" is more like a "cross my heart, hope to die" promise that doesn't mean much.
BB_TX
NFPA is not part of RVIA. Separate entities. However, RVIA uses the NFPA 1192 standard as their standard for design of RVs. Much like cities use NFPA 70 National Electric Code for their building codes.
The NFPA 1192 standard is a little grey in that area. It states that where an RV has more than one sleeping area and one area uses the door as the primary means of escape then no other means of escape is required for that area. That is a pretty far reach for the manufacturer to claim the forward door is the primary means for escape from a rear sleeping area, but I would guess that is their poor reasoning.
For a MH, 1192 permits the driver's door can be the secondary exit. That means a long MH with sleeping in the rear would be permitted to use the two doors at the front as the primary and secondary means of escape.
Would probably require a law suit and a court legal ruling to get any action from the manufacturer. But it would not hurt to push it as far as you can without getting into court battles.
el_jefe1
I don't think that's it, as the egress window in the front bedroom has a screen and works for ventilation just fine. From what I'm reading in NFPA (which is part of the RVIA) sticker on the side, each sleeping area must have 2 exits. The door is one, but there must be another one. As I'm reading it, my trailer is actually out of compliance with the NFPA standard, even though they claim it meets it.
That's why I don't understand it. Is an emergency window of a similar size that much more expensive than a slider?
wildtoad
Donโ€™t know about Keystone but in my MH the egress window is small and not meant to be opened except for emergency exits. NO screen, NO way to prop it open. Some owners have modified it to be useable as a ventilation window. As is, it is doubtful that the window is helpful in the case of a fire.
Perhaps Keystone is in compliance and the beef might be better aimed at the standard. I have no clue as to why they would swap out an egress windows for a slider one, UNLESS the egress widow is not usable for ventilation as is the case in my MH.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
