Flan's avatar
Flan
Winterize with low point drains
First year with the camper going into winter. I notice it has a set of hot/cold low point drains out back and a drain on the fresh water tank. Is there still a need to blow out the lines if using the drains? I opened all the faucets to break vacuum, even opened the blowoff valve on the hot water heater to break vacuum in there. Am I ok to pour some rv antifreeze down the drains and call it good?
Thanks
