TKW
Nov 13, 2018Explorer
Winterizing Question: Is My HWT Check Valve Leaking?
![](https://i.imgur.com/N6s5JSrl.jpg)
This pic is the HWT bypass set-up of my present TT. It only has one bypass valve & a check valve at the hot water outlet. Since last season, I started to blow the system clear of water before pumping anti-freeze in. After draining the HWT (with some residual water remains), compressor set at 40 psi and HWT inlet on bypass, I can hear water sloshing inside the tank. Theoretically, there shouldn't be air blowing in the tank. Do I have a leaky check valve?
