โOct-21-2019 07:22 PM
โOct-25-2019 08:31 PM
โOct-25-2019 08:30 PM
Camper8251 wrote:
this cool thing called Google found your owners manual.......
https://starcraftrv.com/wp-content/uploads/2017/11/2016-Autumn-Ridge.pdf
โOct-23-2019 07:13 PM
โOct-23-2019 06:46 PM
โOct-23-2019 05:57 PM
โOct-23-2019 02:50 PM
โOct-23-2019 02:46 PM
โOct-23-2019 06:35 AM
โOct-23-2019 05:03 AM
โOct-22-2019 07:24 PM
Beverley&Ken wrote:
That white 'nut' is actually a nylon drain plug, use a 1" socket to remove, then open the pressure relief valve and it will drain the water heater. Important have city water disconnected/turned off and water pump turned off as well as turning off the heater controls, gas and electric (if equipped). Also water temp should be cool.
Bypassing the heater for winterization is done on the inside of the RV, behind the heater. One or three valve system.
Ken
If you don't relieve the pressure, before removing the plug, you will have an unexpected shower. plus the plug comes out much easier.
โOct-22-2019 07:22 PM
โOct-22-2019 01:58 PM
โOct-22-2019 12:31 PM
โOct-22-2019 12:12 PM
