pnichols
Jul 23, 2018Explorer II
jaycocreek wrote:
There is an old saying in the hunting world to use enough gun and that saying should, but does not, carry over into generators meaning why try to make a 2K generator do a 3K generators work, just like why take a .243 on a once in a lifetime Elk hunt...It will work if everything is right but Elk hunting does not give everything is just right shots all the time.
Good point!
I guess your point is why our RV has a built-in 4K watt generator in addition to a 650 watt portable generator we carry along, and ... the last time I went hunting it was with a .300 Winchester Magnum. Plenty of power is the name of the game - both electrically and otherwise.
By the way, a generator is not only for A/C or a microwave. What if your RV's propane or diesel heating system should fail during an RV excursion in colder temperatures? You want to go home ... or just use an electric heater powered by your generator?
I believe in RV generators not because I will need them, but because I might need them.
44,030 PostsLatest Activity: Jan 21, 2025
