Young Jedi needs help, you may be my only hope...
Ryan_Djedi_
Hi everybody, thank you so much for your time. I'm looking at buying a 2004 prowler extreme TT. The price seems right at 8500, but I noticed some soft wood on top of the slide.
Is that a deal breaker? It was definitely crackling, but didn't seem rotted through.
Everything else seemed Ok, but then again I know almost nothing. I walked on the roof, and stomped around the tub and such, didn;t see any signs of damage.
Also, is that actually a good price? I like the idea of the extra insulation, as i will be hermiting out in a field for the winter.
Thank you so much, I really appreciate it.
Ryan.
18 REPLIES 18
Ryan_Djedi_
Thank you Obi Wan Fulltimer.
Any advice on what i should look for in that 8k range? I def want a slide and preferably the rear lounge style, as I will be hosting people often.
Thank you.
Ryan_Djedi_
Thank you for your response. Nada says 10-12k. It is a regal extreme, which I believe to be an upgrade.
newman_fulltime
young jedi listen to yoda get in your cruiser and fly away fast at warp speed gget better for the price.
Do not just settle
MNRon
You might check nada.com for comparison pricing. I'm not familiar with the TT you're looking at but $8500 for a 2004 Prowler sounds on the high end to me, especially if there's any water damage.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
