mkirsch
Aug 21, 2023Nomad II
Francis wrote:
Our windows are crank-out jalousies with attached interior screens so using a window is out of the question: we do not want to remove the whole window unit for a retro. The issue of draining the moisture from the A/C won't work with the window. Perhaps a bucket with a cover that has been cut for a hole to fit the drain hose. This works for us to drain gray water out to an enclosed bucket when necessary. We also have a portable dehumidifier but it is ineffective.
Modern portable ACs don't need to be drained very often if at all. The moisture is vaporized and sent out the exhaust tube.
I drained mine a sum total of TWICE in all the years I owned it.
You do you, though.
About Truck Camper Group
227 PostsLatest Activity: Feb 17, 2025
