or how to install springs so you can handle your 5th wheel trailer a bit better.. see what I mean about the crossover benifit, no one that is looking for a way to get rid of some of the sage when hauling their 5th wheel will ever see this if it stays in here as they think its all about truck campers, where this video has lots of value to 5th wheel haulers also.
- Camper_Jeff___KOct 18, 2024Navigator
It increases vehicle height by 4 to 5 inches so it may not actually be beneficial to fifth wheel users. They typically don't look for ground clearance. Truck Campers, we can use increased ground clearance. So can truck toppers, and tent campers. Travel trailers, not so much either. Any tow vehicle can use better suspension for sure but they would be better lower where the vehicle is less tippy due to height.
To really handle my recent posts on truck mechanical topics and similar posts if any by others, a good solution would be to create a new category, "Truck Improvements, Repairs, Enhancements" That way, anybody from any forum knows where to look for truck mechanical information.
It is Good Sam's forum so do whatever your Moderator training commands.
- StirCrazyOct 20, 2024Moderator
I was typing a responce yesterday mornign when the power went out for 4 hours fromn a car crash..
anyways I was going to ask you if thoes lifted the truck much, thats about the same lift in bed hight I got switching from my 1999 f250 to my 2014 f350. no the resort queens don't look for ground clearance but some of the smaller 5th wheels I have seen up here are set up for off road, and they have both the truck and the 5th lifted, otherwise you run out of clearance between the bed rails and the overhang.. I have seen jacked up flatdecks pulling normal 5ths though.. for the most part there isn't a ton of lifted truck campers out here, I see one every now and then as they get limited in there use once you start jacking them.. it usaly the young hunters that have thoes. Travel trailers is what I see most being pulled by jacked up trucks, its to easy just to add a drop hitch to the truck and away you go.
I did sugest a few name changes as some are pretty confusion and are not intuitive, where some have changed purposes during the migration of the board. one was for the truck fourm, something like "
all about trucks" the exact name doesnt matter, what matters is that we clean up a lot of the group names and make it more intuitive on where to post for people. heck I don't even know where to post my new LiFePO4 build as there is no DIY section anymore the name changed to "DIY Maintenance" well building a battery from scratch isn't "Maintenance" and our old "Technology" section has been changed to "Technical issues" and building a battery isn't a "Issue" so I haven't posted because so many posts just don't fit anywhere.
