Jun-20-2013 07:37 PM
Jul-09-2013 10:55 AM
cycletwo wrote:Huh? I need to speak to someone at Bigfoot Industries in Armstrong, BC. The number you gave is for Bigfoot Leveling Systems - totally unrelated outfit! But thanks anyway.
I spoke with a Bigfoot tech about a week ago at this number. Most helpfull!
1-800-752-9815
Good Luck.
Jun-28-2013 03:24 PM
Jun-22-2013 10:41 PM
Jun-22-2013 05:01 PM
Jun-22-2013 08:46 AM
unbob wrote:
Re "Drill a very small hole through the existing pulled out screw locations to daylight on the other side" - nocando - there is no "other side" - only the interior of the camper which is inaccessible. I will drill out the hole but there is no "other side".
Jun-22-2013 07:31 AM
bigfootford wrote:Thanks Jim! Yes, I'm pretty sure you're correct about the backing plate. But I'm really worried now about it being displaced! I had not thought of that before. I just hope the backing plate is glued to the interior side of the camper wall.
From what I was told, the screws go through the Fiberglass and then into a block of wood/plate. You can confirm that by measuring how deep the actual hole is. The glass in the corners is very thick, maybe 1/8 to 1/4 in.. So if the hole is deeper than that you will know that there is a plate there.
So if they are not helpful then think about doing the following:
The best thing to do in that case is to drill new holes in the Jack bracket and then into the camper.
I would put the original screws back in the holes to hold the plate in place, just in case it is not glued to the inside... You do not want it to become displaced! Make sure you have enough holding strength to do this. If it feels that the plate is loose then you may need to do the following..
Fill the existing holes with West systems resin and filler, then drill them out to put the existing screws back in. Not much holding power but just for looking good.
My jack brackets are bedded in with silicon.
So when you have all your holes drilled I would remount the bracket without the bedding, then remove it if you are satisfied then use the silicon to bed-in and mount the bracket.
Jim
Aug-21-2024 03:08 AM
Can u use metal spreading anchors were the bolts had been ripped out when my jack stand basically did the splits with camper like a geraff bending down to drink water
Aug-21-2024 05:28 AM
You are responding to a topic that's 11 years old. You will probably have better luck posting your question/problem in a new topic.
Aug-21-2024 03:12 AM
Jun-22-2013 07:19 AM
Buzzcut1 wrote:Good idea - only problem is Bigfoot does not have a USA phone number. And I don't have an Int'l calling plan. I'll have to upgrade my calling plan which I believe is an add'l $10 per month. Seems that Bigfoot is now such a small local outfit that they have very little presence in the US market. I'd guess they've lost substantial market share in the US market during their absence from the market several years ago. Too bad, I think they have (or had) a great product.
Placing a call to Bigfoot and asking them what they would do in this case would be one of my first plans of action.
Jun-22-2013 07:13 AM
HMS Beagle wrote:Good advice! Yes, I'll use the Six10 product. And I'll let it harden at least 48 hours before drilling for screws. I think I'll forgo the wooden dowels - seems to me that the Six10 epoxy alone will be adequate and stronger than wood. I plan to first test this idea using a 2x4 to see how well drilling the epoxy and installing the screw works.
If you are going to fill the holes with epoxy, then by all means use the West Six Ten product, it is much better than anything Lowes has on the shelf. It is VERY good for this purpose and easy to use - the caulking tube dispenser allows you to inject it deep into the holes without bubbles. It is thickened enough that it will not run out of the hole, even an overhead one. It will take at least overnight to harden to strength, 24 hours would be better. You can speed that up with some heat.
However epoxy at its best will not hold as well as the original wood and fiberglass. I personally would be reluctant to drill holes for dowels, these would necessarily have to be fairly large and through the fiberglass, exposing more wood to the elements.
I would attack it this way: Drill a very small hole through the existing pulled out screw locations to daylight on the other side - this is just to allow the air to escape as you inject it with the Six10 epoxy. A very small hole (say 1/16) will allow the air to escape but not much epoxy, too thick. That will allow you to completely will the holes with Six10. I would then drill a couple of additional holes in the bracket at the top and the bottom in new locations and add those screws when I reinstalled. These will be into fresh original material, and after all it is the couple of screws at the top and bottom that are doing most of the work. The result would be indistinguishable in appearance from the original.
Jun-21-2013 10:22 PM
bigfootford wrote:
This incident was not just a jack mount failure. Someone ran into the jack.
Dry rot in a Bigfoot is something that has never been a problem.
The Bigfoot discussed is an all Fiberglass clamshell design.
The backing plate for the jacks may be made of wood but there has never been a jack failure due to the mounting on the camper.
Yes, for all wood framed campers though.
Jim
Jun-21-2013 09:26 PM
Jun-21-2013 08:24 PM
Tarkin75 wrote:
I'd use git rot or some sort of epoxy meant for fixing dry rot. I'd imagine there's been some water infiltration in the bolt holes so a good chance of some dry rot. You can use the git rot epoxy to soak into the wood, then mix it up with some wood fibers to either fill the holes, or use the mixture to glue those dowels in.
later
C
