So what did you do to your Truck Camper today?
Mello_Mike
I saw these threads in some of the other Open Roads RV Forums, but didn't see one for TCs.
I'll start...
I installed Interior LED puck lights and a 12v power outlet.
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
3,114 REPLIES 3,114
Buzzcut1
Nomad II
Nomad II
well when my wife gets home and sees it she will say "Who are you and what did you do with my husband"
I did some spring cleaning, changed out the sheets cleared out the counters , cabinets and shower, resealed some seams on the exterior storage comparments...etc
my tidy 08 Lance 1055
The Dry Bath
kitchen and bed
dining
some old guy with a buzzcut
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
MAV_8801
Took the truck to the Chevy Dealer yesterday for a Lube and a oil change.. Also had the steering damper replaced and an alignment preformed. I also had a bulb out in the rear tail light assembly. I bought all eight bulbs and replaced them. Now she is ready to go for the springtime.
2011 Palomino Maverick 8801, 2005 Chevy 2500HD Crew Duramax/Allison, Timbrens, Bilsteins, Michelin LTX M/S2, Hypertech programer & Honda Eu2000
Camper_Jeff___K
Nomad III
Nomad III
JoeChiOhki wrote:
Camper_Jeff_&_Kelli wrote:
I am performing a battery test on the TCs new AGMs. I've got four lights and the stereo running to see how the battery charge holds up. I started the test about 10:30 and checked it at 6:30. The voltage on the batteries has gone from 12.8-9 Volts down to 12.5-4 Volts and at 8:30, just now, 12.4 steady volts. I'm waiting to see how long it takes to get the batteries down to 12.2 steady Volts. The stereo is rated to use up to 10 amps so I will call that 5 amps since I'm not actually measuring it but it is turned up a little loud to drive the 4x50W amps more. Four lights are on totaling 8 amps. Total amps being used for the test is about 13 amps. Right now, we are at 13 amps for 10 hours or 130 amp hours of output and the batteries are still at 70% or so. 12.2 volts is considered 60%. The other thing this test will let me do is see if the new Power Max, Boon Docker, 45 amp power supply, when turned back on, will kick into the bulk charge mode at 14.6-7 volts.
UPDATE:
It's 10:00 and the test period is over. The battery was registering 12.4-3 volts so I turned on 4 more lamps, 10 more amps for 00:30 minutes and the battery never registered less than 12.3 volts. At 10:00, I turned off the 4 additional lights and the battery voltage went back up to 12.4 volts. I shut off 3 of the other 4 lights and the stereo leaving only 1 twin tube fluorescent lamp operating at 18 W / 1.4 amps. The battery voltage went up to a stable 12.5 volts after what should be an effective 12 hours @ 13 amps for a total of 156 amp hours of usage. Looking at the battery usage table near the bottom of this page, (Northern Arizona Wind & Sun). After 12 hours of 13 AMP load and using the loaded voltage reading of 12.3 volts, my new SEARS PM-1 AGM batteries never discharged below 70% of full charge according to their table for DOD "Depth of Discharge". When I shut off all the loads, leaving only one fixture operating, the voltage read 12.5 volts or 80-90% of a full charge. I am very impressed by the performance of these batteries.
I plugged the Power Max in after the test was over and the voltage output of the power supply only went to 13.2 volts. The power supply did not kick into the bulk charge mode of 14.6 volts. I guess it didn’t recognize that the batteries had discharged enough to warrant a bulk charge. Now I’m really interested in heading out for a weekend with no shore power for a couple days to see how the whole system works with the 4 gauge wiring upgrade to the truck alternator for charging purposes and the solar panels contribution which today was for about 2 hours was measured at 1 amp @ 14.2 volts or 14.2 watts.
While this test is running, I did my weekly walk around the TC. After lots of rain the last couple days I discovered the rear left side exterior compartment had wetness. I looked around for a source but could find no obvious cause. I did notice the putty seal for the TC left rear tail light looked dry and brittle so I removed the fixture. There it was, totally wet inside. I scraped off all the old putty and installed new putty. I also caulked the top and sides of the tail light fixture to further seal it, leaving the bottom un-caulked to allow an escape route for water. It will be a couple days of drying to verify if this fixed the problem or not. I did scrape and caulk a couple suspicious places with the edge metal strip too while I was at it.
If yer steady voltage was at 12.5, the system still thinks yer batteries are at around 85-90% of charge (12.6+ is considered full charge on a wet cell) and went to the appropriate charging state which likely in the design is 13.2 to prevent excess boiling.
Drawn down to a steady voltage of 12.3, mine goes up to the next stage of 13.71 volts, however, the batteries are also cold so their current movement is down as well as it's possible to still be near the batteries available capacity when its core temp is around 40 degrees with a lower voltage.
Yes. The batteries performed much better than expected especially when considering it was only about 38 degrees out and the Power Max Power Supply did as expected since the batteries did not discharge deep enough to initiate a bulk or absorbtion charge cycle. This page has great information about batteries.
Jeff
JoeChiOhki
UPDATE:
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
Camper_Jeff___K
Nomad III
Nomad III
UPDATE:
ahassell
I just picked up my Lance 1988 LC 780 Saturday the 25th. And It needs lots of work. Started by pulling all the stuff out ( seat cushions, the little widow unit they left in it. They had it on a frame and placed the window unit in the pass-through window. They made a home-made mattress to go in the cab over it was 3 inches thick and made with soft foam, The stove didn't work so its gone. They dropped the vent hood, and it was trashed its gone ) started cleaning and checking it out. The vent covers they are all cracked, ( new vents on the way ) ordered a new stove it will be here the 1st. I cleaned some more emptied all the old spices and canned goods left in it. I had to fix one drawer that was broken.
THE CAB OVER AREA IS NOW CLEAN.
Lights now I learned something when I removed the vent hood, I cut the wires then later I noticed that all the lights on the right side where dead ( they were working ) So after about three hours of troubleshooting I found out they are in series cut one wire, and the rest get no power. I FIXED THAT at the moment the right-side lights are working. I have to work on the florescent lights I have to figure out are they 12 v or 110. They were working when I looked at it ( I am hooked up to an extension cord from the side of the house maybe not enough power? )
This weekend I plan to install the stove and clean the Kitchen area re weather strip the door.
JoeChiOhki
Got some new Wobbl-stopprs installed and reused the old ones so I now have two way bracing:
Wobbl-Stopprs, one year later
Got my new swing-away bike rack put together and tested 🙂
New Swing-away Bike rack
And hopefully tonight I will get a chance to write up about my nice new digital thermostat I finally installed in the camper (Had it sitting in bag behind the seat in the truck for a couple months).
CB
Channel 17
Redneck Express
_DJ_1
We have been having weather in the high 40 and low 50. Thought seriously about de winterizing. Yesterday morning was 16 degrees. :E
Guess I better wait another month!!!
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
Brad820
Pulled out the ruptured water heater and inspected all the visible water lines and connections.
Will order a tank replacement as soon as my tax refund arrives.
Buzzcut1
Nomad II
Nomad II
well it's not winterized and I just looked at the outside temp gauge and it has dropped from 70* today to 34* so I checked the forecast and oh******31* tonight with chance of snow all week. I went outside shut all the windows and vents and turned the heater on low to keep things from freezing up. Guess I better to refil that second but empty propane tank tomorrow.
scolew325
I unloaded it after a very windy weekend on the oregon coast but a nice and relaxing one though. Wish it would have lasred longer.
Scott T. Lewis
Brad820
Washed, waxed, cleaned interior, on our "new to us" 1999 Lance 820. Still have a lot to do to it before it is useable, but this is my first truck camper. Thanks Dan - you know why,
clinthia
Not actually today but, recently.
Replaced the old batwing with a Jack antenna.
and installed digital thermostat.
Clint
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
JoeChiOhki
Put battery watering caps on the Group 27 Deep cycle under the hood of the truck and topped up the water in all the batteries.
Enjoying my new second set of Wobbl-Stoppers with the high winds blowing through and the camper not moving a budge.
CB
Channel 17
Redneck Express
dakonthemountai
Replaced the yellowed outside stove vent damper assembly.
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
