โOct-30-2011 11:29 AM
โApr-17-2015 06:10 AM
Clarryhill wrote:WNYBob wrote:
Sorry, I'm new to posting photo's.
How's this.
Now that's enough to spoil your afternoon...
โApr-14-2015 06:23 PM
Rbertalotto wrote:
Well.....I'm upset.....I spent a ton of time working on my Palomino Bronco to get it ready for the season. Today I decided to take the cushions outside to air them out and here is what I found under the dinette side...
Soggy chip board!!!! Dan Nabit! The front section is right where the front jack is located. It's a mess....
I cleaned out any old caulking I could find and resealed EVERYTHING! I used masking tape so I'd have a nice clean line where the new caulk meets the aluminum siding.
But there was no clear place that I could see that water was getting inside.
Once it all dries out I need to figure out a way to rebuild this area. Fun.....:M
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โApr-14-2015 03:27 PM
โApr-14-2015 12:20 PM
โApr-14-2015 12:11 PM
How's this.
โApr-14-2015 11:52 AM
Bedlam wrote:Clarryhill wrote:WNYBob wrote:
I de-winterized the TC today. Things went well until I tried to fill the hot water tank. Water all over! See the picture of what happens when you don't winterize properly. I didn't pull the plug in the tank. It had over 5 gal. in it over the coldest February in Buffalo history.
http://1drv.ms/1a2IaVY
Don't know what you use for photos, but not something I want to get involved with...
Those are photos shared through Microsoft's One Drive. The permissions are not set correctly and the reason why login is required.
โApr-14-2015 10:54 AM
โApr-14-2015 10:33 AM
WNYBob wrote:
โApr-14-2015 06:01 AM
โApr-14-2015 05:41 AM
โApr-14-2015 05:30 AM
http://1drv.ms/1II9JD7
โApr-13-2015 08:11 PM
โApr-13-2015 02:44 PM
philclouse wrote:JoeChiOhki wrote:where is the thread located? Sounds like,a great plan.philclouse wrote:JoeChiOhki wrote:hey Joe, are you rebuilding the kit? Would love to see some pics and a blog of the progress when you start.
Finishing the yard so I can free up funds to build the new body for my camper.
Yeah, doing a ground up rebuild/remodel, the old girl's frame has been damaged too many times and repairs are near wall-off projects, so I got a set of blue prints to make the mark 2 bigger and better, while keeping the classic look as much as possible (gonna likely mix the original aluminum with some filon).
The original KIT will supply alot of materials for the new KIT (keeping the badging and as much of the KIT look as possible, down to recycling the interior wall board, though on a far beefier frame.
The new camper will likely be at closer in weight to some of her successors than the original 2200lb camper she started out as due to things like going to a 2x lumber frame, instead of the 1x that she originallly was built with (and why she suffered frame failures in several spots).
I have a thread that was my starting spot for plotting out some other changes I am planning on trying to make, including building my own version of a snap n nap from the Amerigos/Kamp Kings for the rear, since she'll be reborn as a side entry unit.
CB
Channel 17Redneck Express
โApr-13-2015 08:45 AM
โApr-13-2015 07:52 AM
