KD4UPL wrote:
Torque lift super truss is the best there is, probably overkill fir such a short overhang. I used one that was 48"with my 11' truck camper. Before that I used a Reese 48" extension. It worked fine but had much more plan than the tork lift set uo.
A boat won't have 10 - 15% tongue weight. 5 - 8 will be more realistic. You will likely be over GVWR but as long as you don't exceed axle or tire weights you'll be fine.
Short overhang? You do realize that those specific campers in that specific truck result in about a 3ft overhang? Similar overhang to your 11’ camper.
