vidotchis wrote:
Hi there, I am looking for any helpful considerations. Considering a 3500 SRW 6.7 HO for a truck camper. Will be right at payload capacity. Pros/cons of air suspension, mega vs cc (longer vs shorter wheel base) etc. I've heard air is good for slightly better ride offloaded and loading/unloading camper but also that it's a waste if loaded a lot of time and could be a service expense down the line. Mega vs. CC is mostly longer wheel base. Going SRW for off-road capability but nothing too aggressive. And snow driving unloaded in deep winter. Any other items to note would be appreciated!
I'm sorry but is there a actual specific question here?
You've inadvertently touched a swath of topics that are hotly debated almost constantly here.
Some folks care about 'payload' and others not so much. If your one that cares keep in mind that whatever camper your looking at you'll need to add ~+1000lbs to the dry weight to be in the ball park of the wet and ready for camping weight.
Whatever truck your considering using there are likely 1000's of folks using it to haul campers on/off road. Generally speaking just about everybody makes modifications to their truck to better carry/handle a top heavy load like a camper.
Please never overload the weight capacity of your tires.
The 'big 3' all make trucks that are used as you've described. Pick one.
- Mark0.
