okiehutch's avatar
okiehutch
Towing a fiver with a 9' flatbed
Hello all. Hopefully a question is OK for a first post. It is what led me to the forums here.
I have a 2008 F350 Dually with a 9' long 100" wide flatbed on it. I am wanting to use this as a tow rig for a fifth wheel but I am not sure the corners of the bed will clear the front of the trailer. I have looked online but can not find what the standard distance is on a fifth wheel from the king pin to the front of the trailer.
Currently it has a fold down gooseneck ball (not recessed) that is actually already a couple inches behind the rear axle. I know it should be over or slightly in front of the rear axle but this was a used flatbed I bought to replace the rusty factory bed. So the gooseneck ball is behind the rear axle a couple inches. With it being a 9' long bed I am not concerned about the hitch to cab clearance or any cab hits. And since it is a flatbed I do not have to worry about it hitting the top of the bed.
But I am concerned the rear corners could hit the front of the fifth wheel in turns. I have NOT purchased a fiver yet or I would just go measure it. Another thought is this bed is 3" taller than most beds. Is there a standard height of the pin box?
I have not decided if I am going to use a goose neck adapter or fabricate a mount for a fifth wheel hitch. I have a Reese 22K fifth wheel hitch and the height on it is adjustable.....I am just concerned that the taller than normal bed height will make the top of the hitch set to high if I go this route. I know you want the fiver to set level when setting on the fiver hitch to make the axle load equal.
So basically, is there a standard measurement that manufactures use from the king pin to the front of the trailer? And is there a standard hitch height that the manufactures use to design the trailers?
Thanks a bunch for reading this long winded post and any help you might give. Below are some pics to clarify what I have to work with.
Hutch in Oklahoma
Moderator edit to resize pictures to forum recommended limit of 640px maximum width.
