VA-Apraisr's avatar
VA-Apraisr
Jun 08, 2023
Dometic RTX 2000 12v using Solar.....?
Was looking into this as an option for my boondock camping in my 28' Class C 4x4. I was thinking about using the bedroom vent as a location to mount this 12v unit as a secondary a/c source. I don't want to give up my normal 110v system that I normally run using the generator.
My thoughts were use it only at nighttime to keep the bedroom cool, if needed. I've already got 200amp hour lithium batteries and would need to install an additional 270amp hour batteries to give me at least 10-14 hours of battery life (assuming 30amps used per hour). This would eliminate the generator noise as well as noise-restrictions in many campgrounds for running a generator from 10pm-6am. Is anyone currently using this system or planning on it?
