wolfe10
Nov 06, 2022Explorer
With a two stage engine compression brake, you WILL have an electric signal that both downshifts the Allison (left or only shift pad window will change from 6 to some lower gear-- often 2nd or 4th) AND will signal the engine ECU to apply either 3 (low) or 6 (high) compression braking.
38,718 PostsLatest Activity: Nov 06, 2018
