JessicaSouth937's avatar
Aug 11, 2023
Fuel pump
Please Help!!!
I have a 1995 Chevrolet Holiday Rambler Endeavor and the fuel pump went out and I need to replace it ASAP! I'm having trouble finding out a make or model that will work.Help!!
  • Bruce Brown wrote:
    udidwht wrote:
    GM or Ford chassis?
    You must have missed where he said 1995 Chevrolet.
    It’s ok, she won’t be back. Doesn’t matter.
  • udidwht wrote:
    GM or Ford chassis?
  • Look at the VIN tag nect to the drivers seat, look at date of incomplete chassis,
    That is your model year of your chevy P30 chassis ,
    That is the info you want to give to the guy at the parts counter
    Chevy P30 Motorhome Chassis
    And year
    And he will find the correct in tank fuel pump
    The brand name of the RV means zero nada nothing when you are sourcing chassis parts, P30 Motorhome Chassis is one version of the P30 truck chassis ,. Which is now Work Horse chassis
    My 3rd MH was a 92 Komfort on a P30 chassis , and measure your wheel base , distance between front and rear axles , mine was 218 inches, it makes a difference on some things like springs, lengthy of drive shaft 3 pcs, number of U joints in drive line size of gas tank etc
  • Rockauto has good selection with good information, O'Reilly's have several different models in stock.
    Not sure of what your issue of finding stand alone fuel pump verssus full assembly with sending unit.
  • Any good auto parts store can tell you better than most anyone here.
  • Fuel Tank Sender GMB 530-9560 Bought mine off Ebay
    Fuel pump only can be bought from most auto parts stores
    Which fuel tank do you have?
