CA_Traveler
Sep 24, 2023Explorer III
The salesman switch (that is what you are describing right?) operates a large solenoid that disconnects much of the DC which should immideately come back on when you press the switch. Check the solenoid as they become pitted from switching DC loads.
Battery charged is an interesting thought as the charger should not be switched but maybe it's been changed. And have the batteries load tested as a possible issue.
38,718 PostsLatest Activity: May 03, 2025
