salem
Mar 17, 2018Explorer
RV drinking Water Hose
Some of the white hoses are 1/2" and some are 5/8". Any reason to choose one over the other? Actually, I had never even noticed the difference till I was shopping for one earlier.
mgirardo wrote:Cummins12V98 wrote:
If you want a hose that will last you forever and is easy to coil in cold weather and it does NOT get fat. I highly suggest logging into "rvfilterstore.com" their hoses and end connections are top quality. Don't waste your time looking unless you are willing to part with your $$$. I purchased three different lengths. Been full timing with them for over two years, still are in perfect condition.
I believe the proper link is https://www.rvwaterfilterstore.com
-Michael
donn0128 wrote:
5/8 will gove you more flow.
oyarsa wrote:
And wouldn't the 1/2" provide more pressure? If that's an issue, which probably isn't considering the recommendation to use a pressure regulator.
