TechWriter
Oct 25, 2022Explorer
3 tons wrote:
That is a truly a Masterful install Sir, and the GX panel interface is outstanding !!…Just curious, though not depicted in the schematic, have you considered installing a sub-panel to sequester certain AC loads (e.g. converter-charger, refer, water heater, possibly air conditioner?) away from the inverter (to prevent inadvertent battery drawdown)?
Nope. The whole purpose of installing the Victron Multiplus II was to be able to connect it directly the my transfer switch w/o using a sub panel.
My fridge is AC or propane so I can force it into propane mode, and my water heater is propane only.
Yes, my two ACs could run off my batteries as well as other appliances like an AC heater.
However, my inverter is set to shut off when battery voltage drops below a preset voltage.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
