ktmrfs
Aug 25, 2023Explorer III
ScottG wrote:
Here's the problem with soft start caps; If the original cap dies while the AC is running, rather than stopping like it normally would the AC will continue to run on the new cap and destroy the compressor.
Ones I've installed have a thermistor or other cutout on the soft start connection so it opens after a short period of time, and only leaves the run cap in the circuit. Or the motor may have a centrifical switch that keeps the start cap out of the circuit once the motor gets up to speed. I've seen both schemes on motors with a start and run cap.
In fact my current coleman =AC units have start and run caps installed from the factory. Same as an aftermarket, the start cap drops out of the circuit after startup and won't be energized again till a stop and then start occurrs.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
