_1Flyboy's avatar
_1Flyboy
No 110 Volts to Hot Water Heater Element
….. Good morning all… Suburban SW6DEL not getting 110 Volts to the heater element. Rocker switch on control panel is sending out 12 Volts when turned on. Is there a relay switch somewhere between the rocker switch and the element? Suggestions appreciated…..TIA
