mickey48
Jul 15, 2023Explorer
12 volt fridges
Looking at a trailer with a 12 volt fridge and solar panel mounted on the roof.  not sure of the size of panel.  My question is this.  how can i tell if the panel is charging the battery?
mickey48 wrote:Yes IF it's a full battery disconnect switch, but generaly no as Barney stated.
when parking trailer for extended period of time can i just turn 12v fridge off inside and battery disconnect switch off , will my battery hold a charge?
Boon Docker wrote:That's a common misconception. The controller amps first power any house loads which can be significant and the difference will then charge the battery. Only a battery monitor with a shunt can determine battery charge, SOC etc
The charge controller should indicate the charge going to the battery.
Boomerweps wrote:valhalla360 wrote:
- How many "usable" amp-hours does your battery bank have (lead-acid batteries should only use 50% of the rated amp-hr and lithium should only use 80% of the rated amp-hr...using more can prematurely age the batteries). Convert to watt-hours by multiplying by 12.
Where is the reference about “only use Lithium to 80% rated amp hour” stated clearly by a battery maker? I’ve never seen it referenced except on this forum. I’ve read where a LiFePO4 retains 80% capacity after its expected recharge cycle life is exceeded. I’ve also read where you can fully discharge them and then fully recharge them with no damage.
