ScottG
Aug 23, 2023Nomad
thomas201 wrote:
A year and a half in, no problems, no trips for service except oil changes and tire rotations, plus two state inspections.
Tows a 10K fifth wheel well. Mine has the 4.3 rear ends. I do not normally lock out 9th and 10th gears, just let the transmission do its thing.
My last truck was a 2012 6.7 diesel. The 2022 7.3 does not pull as well, and it takes more brake applications going down hill. I had an aux tank on the diesel, and I have installed an aux tank on the gas. The gas truck is a super cab, so with the 34 gallon factory tank, and the 41 gallon aux tank, at about 8.8 mpg towing, I get a bit over 500 miles of running per day.
A better compromise for me, with the simpler engine and emission controls. However, I will not know if I made the right decision for a few more years. I will just have to wait and see if it is a good high mileage truck.
At the risk of hijacking, would you mind telling me what kind of mileage you see when you're not towing?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.213 PostsLatest Activity: May 10, 2025
