Sort By
- buckyExplorer IIWater leak detector?
- OP: Have you tried to get any information off the unit? May have to remove from mounting to look at the back.
Hope we didn't scare the OP away! - Grit_dogNavigatorCould be a bomb?
Lol. (Don’t shoot the messenger, just going off the clues given thus far…) - eHoeflerExplorer IISounds like an LP detector. It is over 7 years old, replace it
- BB_TXNomadDefinitely post a picture. I don’t think there would be a propane detector or carbon monoxide detector under a sink.
How to post a picture. - CA_TravelerExplorer III
Grit dog wrote:
Deal me in - Could this be some electronic system like a charger or inverter?
Let play guess what that random beeping light is….
Emblethen had a couple great guesses but those aren’t typically “hidden” IE inside a cabinet like the OP described.
Who’s next?
Or HW that was drained? :@ - CA_TravelerExplorer III
QCMan wrote:
Normally it's money :B but in this case a typo? :h
What did you drain out of the tenants? - QCManNomad IIIWhat did you drain out of the tenants?
- MFLNomad II
enblethen wrote:
LP detector? Carbon Monoxide detector?
Does it have any identifying label?
^This
On a 2011 trailer a detector likely needs to be replaced, unless an obvious reason for it doing it's job, such as bad appliance combustion, or propane leaking.
Often times, replacement can be every 5-7 years.
Jerry - Grit_dogNavigatorLet play guess what that random beeping light is….
Who’s next?
About Travel Trailer Group
44,030 PostsLatest Activity: May 05, 2025
