Jul-26-2023 10:31 AM
Aug-06-2023 11:28 AM
bgum wrote:Thanks for the suggestion. Nice floorplan. Just a tad too large and heavy.
Rockwood geo pro 15
Dry weight 2700 pounds.
Aug-05-2023 05:42 PM
Jul-27-2023 07:48 AM
Jul-26-2023 07:41 PM
otrfun wrote:Reisender wrote:Nice rig! Good to hear you've been happy with your T@B.
Hi OTRfun. We don’t have the T@B320 but have a T@B400 with the Alde heat and hot water system . It is a 2022 model. We have camped roughly 110 days in it in the last 18 months and regularly use the Alde both on propane and electric. It has not had any problems and does a good job.
We also haven’t had any problem with the AC unit but don’t use it much.
The T@B has been trouble free after more than 22000 kilometres all over Canada and extensively in BC. Not a single glitch although the outside black moulding along the top pulled away a bit on top. I pushed it back in and it has been fine since then.
Hope you find what you are looking for.
According to NuCamp you have to flush the Alde glycol system every two years. Any idea what this would cost if not done DIY?
Jul-26-2023 07:33 PM
bgum wrote:I hear ya; however, we're trying to keep our loaded weight below 3000 lbs. The T@B 320's dry weight is approx 2000 lbs., the Mini-Max approx. 2300 lbs. Compromises must be made.
We had a tab boondock and it was a way to small for us. Shower and toilet were nearly useless due to size.
Everything worked fine but far too small and shape of teardrop made usable room even smaller.
The minimax appears a little larger but not enough.
We currently have a Airstream Bambi 16rb while not any longer has much more usable space and we can stand in both bath and rest of rv.
Look at a small square rv and you will have more usable space and save some money.
Jul-26-2023 07:22 PM
Jul-26-2023 02:23 PM
otrfun wrote:
Been looking at the NuCamp T@B320 S and Little Guy Mini-Max teardrop travel trailers.
They both seem to be competitive in terms of pricing and features; however, we have some concerns:
The T@B 320 S gives us pause because of the Alde heating system and the so-called central air a/c system. Both are non-standard systems which would make warranty support, parts, replacement, and DIY maintenance more difficult. Also, not sure what to make of the 5 gal cassette toilet system . . .
At first glance, the large acrylic window on the rear, middle of the Mini-Max seems like a cool feature. Unfortunately, we've heard reports of the 13.5 a/c having problems keeping it cool because of it. Typically, you can't close the shade on a large acrylic window without the risk of trapping heat and melting the plastic window enclosure. Is this true for the Mini-Max?
Comments or opinions? Any input ref their overall reliability, quality, and general usability?
Thanks!
Jul-26-2023 01:41 PM
