Canadian_Rainbi
Nov 22, 2013Explorer
Tequila wrote:
I usually just use the screw top type you can get in Mexico. See picture below, not screw top, but you can get them at some places in the US and you can find them quite readily in Mexico. It is pretty easy to simply transfer water from any other brand, or if it is the same, just exchange them. Water is available at all OXXO stores which are often attached to Pemex stations. Water is cheap enough that if you are worried about spillage, just dump it out before travel days. I have even seen people filling their fresh water tanks with bottled water. It is not worth trying to purify water. I do put 4 oz of peroxide per 50 gallons in my fresh water tank, just in case I forget & brush my teeth with it, and I put a small amount of bleach in the dish water.
You can buy tippers that fit the standard 5 gallon tanks down there for about $20, You can just chuck it on the bed during transit.
Delivery in RV parks in Mexico is also common.
Some brands are screw tops, which we look for. Also available in grocery stores--Mega, Soriana, etc.
Unless you are going out into the sticks I wouldn't bother about filters etc. You can uses regular chlorine bleach to sterilise water and Brita water filter to take the chlorine taste out.
About Bucket List Trips
13,488 PostsLatest Activity: Jul 25, 2025
