reed_cundiff's avatar
reed_cundiff
Badly grounded power pedestals
A lot of power pedestals on Mexican RV parks are badly grounded which can lead to nasty electric shocks if chassis is touched. We put a grounding cable into frame attached to grounding rod. Did notice a slight shock even so but dry sand is not a good conductor. Poured sea water (we are on beach in Yucatan) around the rod and it works perfectly.
The shock was so bad at Playa Azul that we never plugged in for the following three weeks up West coast of Mexico. Solar and LFP bank was sufficient for electrical requirements to include fridge on AC (2.5 kW PSWI) during day with propane at night.
  • GordonThree wrote:
    Sounds like you have something else going on, like hot and neutral reversed.
    What's your EMS say?
    Does sound like issue is with RV electrical vs the various/different power pedestals in Mexico.
    Could be in RV Power Cord, could be loose wiring in Main Power Panel and if you have bad element in water heater it can cause 'hit skin' condition
  • Sounds like you have something else going on, like hot and neutral reversed.
