Belgique
Apr 28, 2016Explorer
Broke Hot Water Heater in Roca Azul
I should sample some of the ideas you gave me on my Tequila thread!
Hot water heater has been leaking for a week but left it alone for fear of making it worse. It's worse. Had to go in and the elbow fitting going into the tank on the cold water side is broke. As in total broke with part of it threaded in. Haven't seen a RV Mobile Tech around here :) so I'm on my own.
I'm assuming that there is no one that can fix this thing between here and Tucson. It is an Atwood 6 gal. The '08 Winnie tubing is pre-PEX. It looks like it fits on a barb and the compression nut clamps it down. There's no removing it without cutting it and then no replacement stuff here I assume. There is an elbow fitting to the tank that the hose goes on.
I'm thinking that my only option is to somehow get a plug into the tank fitting so that I can at least use the cold water. Home depot stuff is probably metric? It has a winterize by pass on it but water still goes in no matter which way the lever is. And it has a motor aid on it if that makes a difference.
Am I missing something that is an easy fix? I think I'll go ahead and get a new heater in Tucson but we don't plan to be there until 20 May. Goal is to at least have cold water.
Now to find some Tequila!
