Acampingwewillgo wrote:
I'm wondering if the pure truck GPS units do a better job of keeping you off undesirable roads....you know, the roads you wouldn't drive your car on let alone a 45 foot mh?
A pure truck GPS should keep you on "designated" routes to which big commercial truck is restricted by law. This is a much more restrictive routing that possibly used for RVs, if the RV map database is correct. RVs are generally not subject to the "designated highway" legal restriction.
There may be further point restrictions based on size and weight, in some cases. The RV mode should be catching these physical restrictions.
I suspect there is a single point physical restriction in the map database for the route OP prefers to take. The restriction may not be real, or it might have been temporary. But this is more likely the problem than any fundamental flaw in the routing algorithms, and it is something that gets corrected with map updates.
When I first got a routing GPS, it had difficulty getting me from my home to downtown, just ten blocks on a through street that goes to a three-way intersection a block from my house, and the three streets have different names. Garmin couldn't handle it, Streets and Trips couldn't handle it, Mapquest couldn't handle it. They all sourced maps from what was then known as NavTeq. DeLorme Street Atlas knew how to get through that intersection, DeLorme makes their own maps.
NavTeq eventually caught the error, Garmin got the update out first, it was a couple more versions of Streets and Trips before that one was fixed.
Another error I caught on NavTeq maps was in West Lafayette. Going north out of town, the maps had me going up one of the local through roads to turn right on Sagamore Parkway. At point I was to turn, the parkway is elevated, there is no intersection, no ramp, no frontage road. Somebody was coding the intersection points (nodes in GIS terminology) from old maps. The version of S&T I am currently using still has the error.
Not only can you not totally depend on routing programs because of map database errors, you cannot necessarily depend totally on paper maps and atlases. They get out of date as roads are changed, and they simply have errors. Maps used to be drawn from aerial photography, what is seen from the air might be different from the situation on the ground.
Additionally, published maps at one time had intentional errors for the purpose of catching copyright violations. I once tried to take a road that wasn't there in South Carolina to a town that was actually someplace else a couple miles away. I don't remember the map publisher on that one, but I got a map from another publisher that had better information for that location.
You will not find much variation in quality of map databases from brand to brand, as there are not that many companies building routing databases, most brands are buying the same maps. Different brands buy updates at different intervals, and even when you buy two different brands the same day, the vintages of map data could be several years apart.
I've come to like Google Maps because they are doing their own work, rather that buying from someone else, and they are constantly at it, running vehicles on the streets and highways to develop ground truth.
