nycsteve's avatar
nycsteve
EZ Pass with trailer question
Hi
Did a search but couldn't find my answer. The question; I have a pickup with a truck camper. My ezpass will charch the car rate with the camper on which is fine. I will be towing a utilty trailer ,14', with 2 axels. I know they count axels. Should I get a separate ezpass for when I have the camper and am towing the trailer? I don't want to end up being charged a tractor trailer rate. Can you register in some way your rig specs to an ezpass account to avoid overcharges? Is there a recreational vehicle rate opposed to a commercial one?
Thanks.
  • From PA E-ZPass FAQ
    I sometimes pull a camper or trailer with my vehicle.
    Can I still use my transponder? Yes. On the Pennsylvania Turnpike, if the weight of the camper or trailer pushes you into a higher class of vehicle, the higher toll will be charged to your account. If you are traveling on other E-ZPass agency toll roads or bridges, please contact the appropriate agency for further information. Refer to the list participating agencies on FAQ # 2.
    I would think NY E-ZPass would be the same but as the above says you may want to check with them.
  • Seems different states have different rules. Some (most?) require a special ezpass for towing trailers, that lets you change vehicle configuration, the normal automobile ones don't apparently?
    Towing my single axle camper west last winter, I was on the Chicago Skyway long enough to pass a single toll plaza, I went through the ipass / cash lane, and the toll taker said my ezpass had registered the correct amount. I thought it odd, since I only have the automobile ezpass.
  • We just use our regular ez pass and have always been charged for the truck & camper.
