- NoccarExplorerI would rather have the sloppy that this snow and Ice. Sloppy cleans up https://www.rv.net/SharedContent/cfb/images/smile.gif. I can deal with the cold. Not planning to fill the water tanks until I get south far enough that is stay 25+ most of the time. I can deal with the inconvenience of no water in the tanks for a few days. I have dealt with busted pipes in an RV before ( not mine) so I do not want any chance of that. Coming back to Alaska late May so I should have any issues coming back.
- PA12DRVRExplorerOther's have covered the substantive stuff, but don't forget that you're likely to get a pretty dirty rig that time of year.
I'd speculate between Los Anchorage and Sheep Mountain, it will be warm and sloppy, then cold and clean (- ish) for quite a ways until somewhere in BC or Alberta (depending on route) where it will get sloppy again. Paved roads or not, melting slushy snow makes for a dirty rig.....as I'm sure you know living in ER lately. - NoccarExplorerThank you all. I have driven it in the summer but not end of winter. Much appreciate the advice.
- Tee_JayExplorerThere are some parks open in southern BC, and a lot in WA and OR and south. The ones I am familiar with in AB open on or after May 1. You can often share the parking lots with the long haul trucks for an overnight.
- jamesuExplorerThis post might get better responses in the “Alaska” section, (Tried sending this to the Moderator, but these often get way-laid with an “error” msg., as this was.)
- 2gypsies1Explorer IIII think the OP was asking about campground in Alaska/Canada being open - not Indiana/Illinois. :)
- explorenorthExplorerI've headed south from Whitehorse about April 20th the past couple of years, and boondock as far as central BC or Alberta because nothing is open.
- Jayco-noslideExplorerWe typically arrive home to west central Illinois from the South about that time and are able to use our motor home all the way with most campgrounds open by then and sooner. However this would be less so much further north. Of course, we've spent many nights in our motor home well below freezing as long as we have elec. hook-up. Sometimes couldn't be hooked to water and the dump valves may freeze.
- DutchmenSportExplorerIndiana State Parks are open all year round, but water is traditionally turned back on in the campgrounds, dump stations, and bath houses on April 1. "Most" private campgrounds open April 1 also in Indiana.
- pianotunaNomad IIISome cities may have campgrounds open year round. Google your possible stopping places, and phone ahead.
Be sure to winterize the fridge.
About Bucket List Trips
13,488 PostsLatest Activity: Jan 17, 2025
