EEWally's avatar
EEWally
Horizontal Propane Tanks with Old-Style Valve in AK?
Our Lance camper has 2 20-lb horizontal propane tanks. The US DOT grandfathered the old-style valves on these (as long as they are pressure certified, of course).
We've had trouble occasionally in the lower 48 getting a fill because of the old valve. So, we bought one new $160 horizontal tank with the new OPD valve to make sure we could always have at least one filled.
Is the old-style valve going to be a problem in Alaska? What about BC and the Yukon? Is the old valve grandfathered for horizontal tanks in Canada?
Should we buy a 2nd $160 tank?? Yikes!!
Thanks!!!
  • To address the question, you'll probably need to do some explaining to get your tanks filled at most gas stations or the like. There are at least two places in Los Anchorage and in Squarebanks that are propane distributors that are likely to know the rules about horizontal tanks.
  • There are horizontal propane cylinders as well so you need to know what you have. If the container has welded on brackets for permanent mounting it is a Tank, if it just sits in a holder and you can take it out to refill, it's a cylinder.
    As beaslwd said tanks do not need OPD valves, cylinders do.
    In case you want to buy a horizontal cylinder they retail for $255 and are made by Manchester Tank. The product number for the 20# one is 1175TC. Mfg in accordance with DOT 4B, 4BW, and 4E specs. Fill valve and pressure relief are on the end but on top of the end.
  • I've pumped propane in my duties as a camp host.....somebody does not know the propane regulations as well as they should. Horizontal propane tanks are exempt from the OPD regulations. Horizontal tanks used in fork lifts, boats and motorhomes, and other gases used for welding ect.
    http://www.nfpa.org/safety-information/for-consumers/gasoline-and-propane/propane-safety/propane-cylinder-overfilling-prevention-devices
  • Just get the old one re valved with OPD, a friend on the island had his done last year, they would not fill his old valve tanks, yes and they were horizontal tanks also.
