Griffin_sride's avatar
Jul 02, 2014
Horizontal Propane Tanks
Are horizontal propane tanks used on forklifts of any value? I looked a little online and it seems like the horizontal tanks are expensive to replace. I have 4 tanks that were left over from a construction job and not sure if they could be used for an RV application or not. They're in excellent shape and won't need initial inspection for another 7 years (09 manufacture date stamped). Could anyone give me info if these are worth anything or not????
Thanks!!
  • Forklift tanks need to have the relief valve changed every 12 years, so they are due in 5 years, Even so they have value find a local propane dealer and sell them.
  • Dutch_12078 wrote:
    Make sure the tanks have a vapor withdrawal valve in addition to the liquid withdrawal valve many fork lifts use. The liquid withdrawal port cannot be used by your RV for general LP supply purposes.
    Converting them to RV use might not be economically feasible.
    I would list them on Craig's List
  • Make sure the tanks have a vapor withdrawal valve in addition to the liquid withdrawal valve many fork lifts use. The liquid withdrawal port cannot be used by your RV for general LP supply purposes.
  • They actually fit a variety of Industrial equipment so there should be lots of interest.
    As a previous poster suggested ,check with one of the larger Propane suppliers as they would be able to suggest a user in your area that may want to buy a spare or two.
  • Contact a propane distributor for specific information. You may not be able to use them on an RV because of their ratings. As I remember, they must be steel and certified for mounting on a vehicle frame. Even then, a good propane store can use the tanks, and advertising them may locate an end user.
  • Lots of truck camper models use horizontal tanks.....
    Might have Moderator move this to TC Section.
