briansue
8 years agoExplorer
Power Pedestal Connections
We read an online RV newsletter that comes out each Saturday. Electricity is often a topic of discussion. Today there was a survey to try to tell what percent of readers have experienced some sort of bad connections at RV parks/campgrounds. Note that this survey was probably responded to by RVers in the US so there are plenty of bad power pedestals out there. Every power pedestal should be checked before plugging your rig into it.
Campground power pedestal failures (Reader Poll included)
http://rvtravel.com/campground-power-pedestal-failures-reader-poll-included/
I have previously mentioned one of many devices that can be used to check pedestal power. I found that these can now be found on Amazon – not sure where else as the company no longer sells retail. - Prime Products 12-4058 AC Power Line Monitor – I bought two of these and made up a device I can use to quickly check both legs of a 50 amp connection. I can also check any other standard connection. This will tell you if polarity is correct and if you have ground – as well as a digital voltage read out. You can plug one in you rig to monitor voltage.
We bought one of the ISB Solar Basic Voltage Regulators a few years ago in Mexico. I find I have to use ours in the US as well. You would have to use two of them to regulate both legs of a 50 amp connection. I know there have been any number of products mentioned over the years on this forum but this is the only one I have ever seen which can correct both high and low voltage. They work. I have never been able to find one in the US for a decent price.
Corrector of Voltage 8 and 4 KVA
http://www.isbmex.com/productos/corrector-de-voltaje-8-y-4-kva
Rated capacity: 4 KVA and 8 KVA
Operating range: 85 V ~ - 147 V ~
Rated voltage: 127 V ~ 60 Hz
Maximum current: 30 A (4 KVA), 60 A (8 KVA)
