- Mr__SteveExplorer
Old-Biscuit wrote:
Prescott to Cottonwood via 89A........NO
Cottonwood to Sedona and then onto Cave Spring..........YES
Prescott to Cave Spring........169 (Dewey) to I-17 (N) to 179 (Sedona) to 89A
OR
89 to I-40 to I-17 to 89A (longer route)
Provided that is the 'cave spring' you are referring to (there's at least 8 in AZ) :H
The route we are thinking is from Prescott (Point of Rocks Campground) to Cave Springs , it does look like its actually on 89A, am I to assume that part of 89A is not a problem? The Cave Springs I am talking about is CAVE SPRINGS at OAK CREEK. This is what we are thinking : 169 (Dewey) to I-17 (N) to 179 (Sedona) to 89A
No problems? just ended up leaving some of my paint on 89N coming up to Prescott, dont need anymore issues. Thank you! :( - Mr__SteveExplorerThank you all for your help, this is a new area for me, just trying to get all in order before I leave.
- nevadanickExplorerYes 169. Go through Prescott Valley to Dewey and turn left on 169 to 17
- Mr__SteveExplorer
nevadanick wrote:
If your wife doesnt like steep winding roads then you definately dont want to go trhough Jerome. Go through Cherry to 17 to get there from Prescott.
Not sure I see Cherry on map, I see heading 169 from Prescott to 17 North. Is that correct? - Mr__SteveExplorer
Thank you. - nevadanickExplorerIf your wife doesnt like steep winding roads then you definately dont want to go trhough Jerome. Go through Cherry to 17 to get there from Prescott.
- Mr__SteveExplorer
2gypsies wrote:
What is your destination from Prescott. I don't know of a Cave Spring around there. Are you trying to get to I-40? I-17? Sedona?
The campground is Cave Springs Campground in Sedona, sorry if I was not clear. My wife is not a fan of steep winding roads so I think I will need to take the longer way around. I will be headng from Point of Rocks campground in Prescott. Thanks! - 2gypsies1Explorer IIIWhat is your destination from Prescott. I don't know of a Cave Spring around there. Are you trying to get to I-40? I-17? Sedona?
- pigman1ExplorerOn the section of the route from Prescott to Clarkdale phones will be intermittent. You will be quite high coming down into Clarkdale and when there is a clear shot to a tower you'll have reception. When you're not, nothing. The route over the mountain is steep and has a large number of close switchbacks. The state has restricted it to NO TRUCKS OVER 50' in length, but there is no restriction on RV's regardless of length. I have driven it in a 38' Diesel Bounder, southwest to northeast, pulling a toad. It was tight, especially on the switchbacks and through Jerome, but if you are a good mountain driver, and your equipment can handle the grades, it is not a major problem. The same general issues will be seen on the section of the route from Sedona northeast. This is the section with steep cliffs right at the road edge that will reach out and touch you if you're not careful. Switchbacks, steep grades and narrow spots are the same as the other section. When you finally get up out of Oak Creek Canyon and onto the mesa, it's a very pretty ride. Same truck length restriction. The stretch of 89A between Clarkdale and Sedona is no problem at all, except for possible traffic and road construction issues st some times.
- Mr__SteveExplorerThank you everyone...I get it. I will be taking the long way around.
About Bucket List Trips
13,488 PostsLatest Activity: Jan 17, 2025
