lukeh wrote:
Each Christmas I travel from Iowa to Ft. Myers, Florida. Year after year we have to carefully time our travels through Atlanta. Does anyone have a good route to skirt Atlanta. I'm driving a diesel pusher with Honda Odyssey toad. Trying to avoid 2 lane or rough roads. Thank you! Safe travels.
Yikes, some dubious advice in this thread. The toll-based lanes are on I-85, which shouldn't be part of your route anyway, so ignore that. If you drive at normal RV speeds, setting yourself up in the HOV lanes would rate you somewhere between annoying and dangerous, so I'd be careful about doing that as well.
Now back to the question you actually asked. If timing to avoid Atlanta rush hour is a problem for you, and bypassing Atlanta is what you want to do, a way to do that on a route of almost exactly the same distance would be to head down to south of Memphis on I-55. Then take US-78, which is a 4-lane, limited access, interstate-quality road and in fact is now designated I-22 over much of its route. I've driven it numerous times and it's a great drive. From Birmingham, you'll need to do a couple short transitions (maybe I-65 to I-20, each would be just a few miles), and then angle southeast on US-280/GA-520 about 260 miles down to I-75. I haven't taken that route through Birmingham, so someone else will need to chime in if it meets your objectives on that segment (and I find Birmingham scarier than Atlanta). From Birmingham on US-280/GA-520, I've only driven the latter portion (again, someone else will need to chime in), but over that stretch it's 4-lane all the way and is my preferred route from east-central Alabama to I-75. Another benefit of this route is that it avoids I-75 south of Atlanta (like around McDonough), which is always under construction, and avoids I-75 north of Atlanta (like around Marietta), which is under construction now for the new Braves stadium. Both of those are worthy ambitions, at least until all of the construction is completed, which will never happen.
Skip
